Det va inget SPL Steg.. Det va soundstream. Men jag kollade på spl steg o hittade detta.
SPL GRLA5500/1D 5500WATT Class D Mono Car Amplifier
* Gorilla Series Class D Digital Monoblock Car Amplifier
* RMS Power Rating:
o 4 ohms: 1700 watts x 1 chan.
o 2 ohms: 2500 watts x 1 chan.
o 1 ohm: 3200 watts x 1 chan.
* Max power output: 5500 Watts
* Regulated MOSFET PMW power supply
* Bass Remote Details (Wired remote bass level control included)
* All connections on the front side for easy installation
* LED power indicators
* Bass Boost (0-18 dB bass boost at 45 Hz)
* Phase Shift (180 Degrees)
* Mono channel operation
* Bridged Synchronization (Strap amps together to double your power!)
* Preamp RCA outputs
* 3-Way system protection circuitry (thermal, overload, and short protection)
* Brilliant silver texture coat finish
* Heavy duty die cast aluminum alloy heatsink for extreme heat dissipation
* Silver-plated RCA level inputs
* Silver-plated screw terminals
* Variable low-pass filter (40-200 Hz, 12 dB/octave)
* Subsonic Filter (12 dB at 20-50 Hz)
* Frequency response: 15-150 Hz
* Dimensions: 17"L x 8-1/4"W x 2-1/8"H
* 1/0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
* Authorized Internet Dealer
* 1-year Manufacturer's warranty
För 3180KR Med Frakt. Och Där va 5x40 säkringar
Blir fan det istället..
