2696
Lådritning till 21" 18" 15"
Designer.
1 260 Inlägg
3 juni 2010
Dannz0 skrev:
Jag har faktiskt kollat på dessa med. Vad e litern i i låda till en/två sådan basar??
    * 18" Competition subwoofer with massively deep sounding bass
    * Nothing comes close to an 18" sub with this much power!
    * Hand-built in the USA (These are put together with extremely strict ratings and standards.  These are known to be one of the best engineered and best quality subs on the market)
    * 2 Year Warranty
    * 1000 watts RMS Rated! (Note this can handle more than 1,000 watts.  It is rated with a stricter standard of power testing, then most other car audio brands)
    * Dual Composite 2-piece Cone
    * Rubatek Foam Surround
    * Cast Aluminum Basket
    * Tork-Tite Terminal
    * 3 ” 8-layer Aluminum Voice Coil• FEA Optimized Motor Structure
    * Triple Stack Magnets
    * Progressive Spiders
    * Wrap around Rubber Gasket
    * 18"
    * Mounting Depth - 9.5"
    * Mounting Hole Diameter - 16.75"
    * Overall Diameter - 18.5"
    * Bolt Hole Circle - 17.5"
    * Motor Width - 6.5"
    * Motor Depth - 3.25"
    * Basket Depth - 6.25"
    * Displacement - 0.22 cu. ft.
    * Weight: 32 lbs.
    * Use Ported Box Only!
    * Ported box volume: 8.0 cubic feet; tuned @ 34 HZ
    * Electrical Q Value -Qes: 0.53
    * Mechanical Q Value -Qms: 6.1
    * Total Speaker Q Value -Qts: 0.48
    * Free Air Resonance -Fs: 33.2 Hz
    * Equivalent Compliance -Vas: 159 liters
    * One-Way, Linear Excursion -Xmax: 22 mm
    * Efficiency -SPL 1W/1m: 92.7 dB SPL
    * Effective Piston Area -Sd: 1210 cm^2
    * DC Resistance -Re: 1.9 ohm
    * Nominal Impedance -Znom: Dual 4 ohm
    * Thermal Power Handling -Pe: 1000 W
    * Force Factor -Bl: 21
Stod till och med i texten du klistrat in... ~226,53Liter per bas.
Men får jag fråga vad du är ute efter med ljudet? Vad har du för budget till steg och batterier?
Senast redigerat av MIKK0 (3 juni 2010)
Remember, remember the fifth of November, the gunpowder treason and plot,
i know of no reason why the gunpowder treason should ever be forgot
572 Inlägg
3 juni 2010
Hehe.. jag läste texten inte så noga.. smile Jag e ute efter djupt och hårt tryck. Slutsteg har jag inget som driver det än.. Kommer köpa ett senare.. Jag måste köpa steg enligt basarna ju.  Batteri har jag två än så länge.. Kommer två till snart
DZ Design På Facebook
Designer.
1 260 Inlägg
3 juni 2010
Eller så kan du testa göra tvärt om, köp så dyrt och bra steg som du kan. Sen köper du basar efter det. För att spela djupt och hårt måste man inte ha 18" basar smile
572 Inlägg
3 juni 2010
Hehe.. Ja min kompis köpte ett slutsteg från ebay för 2700.. Får se hur det e. E det bra så blir det ett såndant.. Det va på 5500watt max och säkrad till 5x40 amp. Så vi får se.. big_smile
Superhedde
255 Inlägg
3 juni 2010
Du kan ju börja med att mäta hur stor låda du får plats med i ditt bagageutrymme. wink
Mvh Mattias Hedin
DJ sedan 1990. Jobbat med billjud sedan 1999. Musikproducent. #mattheroproducer
572 Inlägg
3 juni 2010
Bred 900 Höjd Fram 550 Höjd bak 350 och djup 630. Kan höja Höjd Fram en aning om det behövs. Så stor låda kan jag få..
572 Inlägg
3 juni 2010
Jag har tre 12" som stylingbutiken hade innan.. Men jag vet inte vad dom heter eller vas o allt detdära. Det enda jag vet e att dom e på 1200W max och det ska vara en 34-36 liters låda styck till dom.. Hade velat göra en låda till dom med det måttet jag gav precis.. Men då blir lådan 255 liter. Och det e lite väl mycket. Vill veta hur stor lådan ska vara med en portad låda.. Någon som vet vad basarna heter eller har all infon jag behöver?? Har googlat på det men hittar fan inte dom.. sad
Jag har hittat namnet på dom o det e allt sad
STA SX-W3012 Heter dom
Senast redigerat av Dannz0 (3 juni 2010)
21 761 Inlägg
3 juni 2010
Utgår man ifrån 22 mm material så blir innervolymen ca 203 liter, vilket verkar duga bra till 1 st RE SXX 18 (inte 2 st). Det där förslaget på 226 liter är en "optimal" rekommendation enligt info på deras hemsida, det går att göra mindre låda och ha lite högre avstämning enligt min uppfattning. smile
Senast redigerat av Drönirettab (3 juni 2010)
572 Inlägg
3 juni 2010
Okej.. Ja det låter ju bra.. bara jag får in en 18"are så e jag glad.. wink
21 761 Inlägg
3 juni 2010
Har kollat på 150 liter netto avstämt till 40 Hz med 2 st 6" portar som har 22 cm långa rör, sedan trattar i båda ändar. Med bas och portar blir totala lådvolymen ca 170 liter, fast med tanke på lådstorleken så behövs nog en del stagning och sånt tar ju lite plats också. Vet inte riktigt hur många liter som är lämpligt att räkna bort för stagningen.
572 Inlägg
4 juni 2010
Du har räknat ut till 18"aren va??? Så fall ska jag spara detta=)
21 761 Inlägg
4 juni 2010
Ja, det är till 18" (SXX 18). smile
572 Inlägg
4 juni 2010
Okej.. smile Det va ju bra. Då ska jag spara det tills jag ska bygga..smile
1 312 Inlägg
6 juni 2010
jag har en 18 tummare ligga som spelar ganska bra faktist..
en focal k2 power.. finns mer info på längen..
http://www.blekingebilradio.se/product. … gory_id=26
har en till ett bra pris på typ 4000...
Ljudbutiken.nu
572 Inlägg
6 juni 2010
Okej. Men nej tack.. har en RE Audio 18" för 3000 Ny. som jag ska införskaffa
572 Inlägg
6 juni 2010
Jag hittade en låda till en sån bas jag ska köpa.
Vad tror ni om en sådan??
http://buyafatbox.com/RE%20COMP%20SERIES%20INSIDE%20fatboxusa1.jpg
SPECS:
- DIMENSIONS: 22" HEIGHT, 34" WIDTH, 25" DEPTH
- ALL 1" THICK INDUSTRIAL MDF
- SPINE/NO FLEX BRACING SYSTEM
- 2" FRONT/BAFFLE SUBWOOFER MOUNTING
- ALL JOINTS BONDED, NO LIQUID GLUE MAKING THEM THE STRONGEST PART OF THE ENCLOSURE
- ALL JOINTS SEALED WITH A HARD SEALER, NO SILICONE!
- THIS ENCLOSURE CURES IN A HOT ROOM FOR 24 HOURS
- HEAVY DUTY CHARCOAL OR BLACK CARPET (PLEASE SPECIFY IN PAYPAL NOTES SECTION)
- HEAVY DUTY GOLD BINDING POST TERMINALS EACH WITH GASKETS TO POWER THE BEAST!
Senast redigerat av Dannz0 (6 juni 2010)
Team dBAkuten!
3 263 Inlägg
7 juni 2010
Första tanken är NEJ, den stoppar upp luftflödet till porten.
Men jag har aldrig hört den så man kan inte säkert veta.
Extreme Fiestan 163.4dB
FLEXpressen 154.2dB @ 48Hz & 153.2dB @ 26Hz.
SPL-Hundkojan Svetsning pågår. 125 meter stål kan vara lagom ;)
TEAM dBAkuten
4 693 Inlägg
7 juni 2010
Nej, det lär ju knappast bli något bra flöde i den lådan
Booyakasha!
170 Inlägg
7 juni 2010
#59
Tycker den ser bra ut, välbyggd, bara optimera stagningen med runstav istället så blir den perfekt!
Less is more
http://www.digitalcompaniet.se/
ÅF för: Hertz, Alpine, Amega, Digital Designs, Hifonics, SPL Dynamics, DLS, MDS
4 693 Inlägg
7 juni 2010
#60
Ja då ja. Men inte som den är på bilden
Booyakasha!
