Vettemannen skrev:
Garagemuppen skrev:
Bale skrev:
Haha, bästa kommentaren jag läst på länge!
Bilen hade dock en tjänstevikt på 2049 kg, så den är ju inte så jäkla stor
Trodde dock det var mer.
/Benny
Tog det som stod på Wikipedia.
Manufacturer's specifications
Engine: 1966–67 - 425 cu in (7.0 L) OHV V8, 1968–70 - 455 cu in (7.5 L) OHV V8
Power: 1966–67 - 385 hp (287 kW) @ 4800 rpm, 1968–70 - 375 hp (280 kW) @ 4400 rpm, 400 (298 kW) @ 5000 rpm with option code W-34
Torque: 1966–67 – 475 lb·ft (644 Nm) @ 3200 rpm, 1968–70 – 510 lb·ft (691 Nm) @ 3000 rpm, 500 lb·ft (678 Nm) @ 3200 rpm with option code W-34
Transmission: 3-speed automatic, Turbo-Hydramatic 425 (THM-425)
Final drive ratio: 1966–67 - 3.21:1, 1968–70 - 3.07:1
Wheelbase: 119.0" (3023 mm)
Overall length: 1966–67 - 211" (5359 mm), 1968 - 211.6" (5375 mm), 1969–70 - 214.8" (5456 mm)
Overall height: 52.8" (1341 mm)
Overall width: 78.5" (1994 mm)
Track, front/rear: 63.5" (1613 mm) / 63.0" (1600 mm)
Weight, shipping/curb: 4311/4,496 lb (1955/2039 kg)
Weight distribution, front/rear (%): 60.3/39.7
