ja alltså nog kan det funka bara framvagnen passar rakt på eftersom att bak passar ingen quattro bakvagn bara så där utan bottenplatten i bilen måste ju byggas om ganska ordentligt..
det enklaste sättet att göra det på är :
(kort version = du behöver så gott som hela botten plattan från en audi 80 quattro B2 mellan 1979-1986)
Front Anti-rollbar
Front Anti-rollbar drop links
Front subframe
Brake proportioning valve and mounting bracket
Exhaust Manifold
Exhaust downpipe
US code Gearbox
Gearshifter mechanism
Gearshifter boot, lever and knob
Clutch assembly
Propeller shaft assembly
Front driveshafts
Front-to-rear brake line
E-brake / Handbrake lever and boot
Center exhaust box
Rear exhaust box
Underbody heatshields
Rear subframe
Rear Differential assembly
Rear driveshafts
Rear calipers
Rear disks
Rear Strut assemblies
E-brake / handbrake cables
Brakeline T piece
Rear brake hoses
Rear screen (quattro script in heater element)
Rear side windows (quattro decals)
Gas / Petrol tank
Trunk / Boot carpets
Cabin carpets, front and rear
Fuel accumulator
Fuel pump and fuel pipe protection covers
Now you also need the lower front bulkhead assembly from a 4000q. The ENTIRE floorpan from the 4000q. You also need the trunk floor from a 4000q. Plus the rear inner wheel arches with the correct upper strut mount locations. From a 4000q.
Senast redigerat av fax110 (8 september 2013)
