3730
Opel Ascona B 1.9td motorbyte #Bästebrukisen (no more 1.9 )
Hej detta är mitt första projekt där jag byter motor i en Ascona B (har nu spårat och det vankas helrenovering)
10 340 Visningar
Uppdaterades senast 17 oktober 2017
19 Inlägg
8 oktober 2016
https://www1.garaget.org/gallery/images/197/196259/196259-391b22bfce34fbebeaa49fe0c91680b9.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-14d46732002f0df095760a0544c477e4.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-354d4445c8f024b78d7107981e6e00d3.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-9ae41edc345da02d9fc055b7891cad0d.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-9932ff85580883a9092ebcc0a851348b.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-b53de8ab6a2e30a975b83052d2b2bd4c.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-ca8486c8279b7c91a6e7e4724c9f97ed.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-6781343a87bc739bb7db46476befa262.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-b90d21eddf8c1f17fc7835c5dc37e71a.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-e8c6ef5bfee3610331e77804acd78a9b.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-f501a6c7d49583db7bc8445eb1379fcc.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-3c8d5c6c637f8aaf9fd056b219f3fa3b.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-9dfef4ae147199355e75b711d3eb6c52.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-fb5e6eb7246dadce2c1be897f96d754c.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-271bcef541467debfaa7efdcfd5b7bc2.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-8da9984a1cf71f8bb786b88cf99ff2e5.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-1b44cbf86c3e4330c9ce6a85467ee822.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-e82c044f29c1e0caa80ab153a43acae5.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-d738d7f329f626df5d023e2b1782349a.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-293eb1f84db9fe5e4bf20845871e7dd3.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-cf8330668a9e88b3a25ab0e185ed6882.jpg
Hej detta är mitt första projekt och hoppas jag kan uppdatera så mycket det bara går!
Snabb beskrivning och statusuppdatering om hur jag ligger till just nu:
Jag har köpt mig en Opel ascona b 1980 4dr som hade en rasad 1900 bensinare som jag ska byta ut mot en 1.9td från en passat 3b och regga.
Det som gjort hittills är att jag med hjälp av lite vänner har lyft ur motorn ur både Opeln och Passaten, köpt adapter platta så jag kan matcha motorn med en Volvo m47 vxl-låda. (adapterplattan köpt på SMT.nu)
Svetsat om ett tråg som jag tog från en annan 1.9 som suttit i en Audi a4 b5 tdi så den ska passa över framvagnsbalken + så tog jag oljepump och pickup från den.
Även lyxat till med en chrome stöta bak (letar en till fram).
Det som är kvar för att få i motorn är:
Korta kardan.
Bygga motorfästen och vxl-lådsfäste.
Dränera gamla soppasystemet från bensin.
Bygga spakställ.
För att få den klar.
Massa småpyssel som byta lite slangar på motorn, bygga avgassystem, dra el mm..
Och till alla som tror man måste ha en 100% komplett verkstad för att skruva, hittills har jag i princip bara använt en 300 kroners verktyksväska från Jula wink (och motorlyft så klart)
Ber om ursäkt för eventuella felstavningar och särskrivningar så jag slipper grammatikpolisen smile
Senast redigerat av Smulpaa (15 oktober 2017)
207 Inlägg
8 oktober 2016
Härligt med skattefri diesel wink
Följer det här ja smile
19 Inlägg
9 oktober 2016
_Budda_ skrev:
Härligt med skattefri diesel ;)
Följer det här ja :)
haha ja det ska bli gött, ska uppdatera så gott det går :)
19 Inlägg
12 oktober 2016
https://www1.garaget.org/gallery/images/197/196259/196259-c1f28816da3ee669bf995d75d72cacfc.jpg
https://www1.garaget.org/gallery/images/197/196259/196259-4a45963f65e7b03007534e99b1b38d59.jpg
Liten uppdatering.
Jag har inte hunnit göra något på bilen då det varit mycket jobb..
Men igår kom i alla fall två stötor till Opeln så nu har jag även en chrome stöta till fram också och som + har jag en reserv till bak :)
213 Inlägg
13 oktober 2016
Håller på med ett liknande projekt, i startgroparna dvs. Hittar du mer än ett svänghjul som är rätt så är jag spekulant på ett.
19 Inlägg
14 oktober 2016
Det ska jag ha med mig i minnet smile
19 Inlägg
30 november 2016
Projektet ligger lite på is då jag letar koppling, jag söker en 22 tandad med ofjädrat centrum till m47. 228mm diameter. om någon vet av vart jag kan hitta detta dela gärna med dig smile
3 182 Inlägg
1 december 2016
följer detta. klart interessant projekt.
19 Inlägg
19 december 2016
Kort update.
Jag har fått reda på att jag ska bli pappa. (yey!)
Så till sommaren kommer det en unge in i bilden så innan dess ska bilen vara klar smile
Jag har hittat en vettig lamell nu så man kan få ihop motorpaketet och komma någon vart men det får vänta till årsskiftet då ekonomin inte räcker till just denna december. smile
ska försöka uppdatera i januari med lite mer framgång smile
Kul att ni gillar projektet och vill följa, vi syns 2017 smile
Garage General
132 Inlägg
20 december 2016
Hej roligt bygge! Hur har du tänkt göra med svänghjul/koppling/lager och startmotor? smile har funderingar på VW diesel i 140 in nämligen smile
Kika gärna i projekttråden, opel manta A får nytt liv med t4:) bruks/busbil
http://www.garaget.org/forum/viewtopic.php?id=315609
19 Inlägg
20 december 2016
svänghjul rekomenderar jag ett enkelmassesvänghjul från en Vagprodukt som kommit med rakställd motor så starkransen är på rätt sida annars måste man svarva om och den ska även vara till för en koppling (typ volvo orginal  m47 tex) med en diameter på 228mm om du ska åka volvolåda.
Sedan om du köper adapterplatta från SMT så får du med ett a4 med massa info där det även står vilka starmotorer som passa (blandannat d24 start).
Så setup:
Svänghjul: Vag (själv har jag från en audi a4 1.9tdi)
Koppling: till lådan du kör med med korrekt diameter (jag kommer köra 6puckad sinter med stumt centrum då jag bara fick tag i ett dubbelmassesvänghjul vilket inte är att rekomendera)
Tryckplatta: orginal från vagprodukten
Urtrampninglager: lådans orginal ska passa så vitt jag vet
Sedan måste du ha ett pilotlager som ska passa över utgåendeaxel från lådan och in i veven på 1.9an 10mm inner och 35mm ytter om jag minns rätt smile
Hoppas jag kunnat hjälpa med mitt dåligt formulerade och stavat svar xD
Senast redigerat av Smulpaa (20 december 2016)
Garage General
132 Inlägg
20 december 2016
Så setup:
Tack så mycket! Äh inte dåligt att lägga ner sån tid på att skriva ett svar ändå big_smile
19 Inlägg
20 december 2016
Så setup:
Kul att det uppskattas och lycka till med ditt project smile
Garage General
132 Inlägg
21 december 2016
Så setup:
Ja absolut, tackar men ska nog göra klart mantan först, du får gärna kika in på min profil och in på projektet smile
19 Inlägg
22 december 2016
Jag har kikat, blir nog grymt när det är klart smile
Garage General
132 Inlägg
22 december 2016
Tackar, ditt med. Kanske syns på nån träff så man får spana in irl smile
19 Inlägg
23 december 2016
hoppas smile
326 Inlägg
23 december 2016
Trevligt projekt! smile Perfekt bil/motorkombo! smile
19 Inlägg
6 januari 2017
Det hoppas jag smile
19 Inlägg
14 mars 2017
Nu har det stått still alldeles för länge men det har berott på att jag inte haft någonstans att hålla på.
Men nu har jag och 3 kompisar hyrt ett garage så nu ska vi kunna skruva smile
https://www1.garaget.org/gallery/images/197/196259/196259-5a34e62e685429a8e44a379796eeab0a.jpg
Senast redigerat av Smulpaa (14 mars 2017)
